nrselect
- northern virginia
250.58 Common Grounding Electrode. Where an ac system
is connected to a grounding electrode in or at a building
or structure, the same electrode shall be used to ground
conductor enclosures and equipment in or on that building or
structure. Where separate services, feeders, or branch circuits
supply a building and are required to be connected to a
grounding electrode(s), the same grounding electrode(s) shall
be used.
Two or more grounding electrodes that are bonded together
shall be considered as a single grounding electrode
system in this sense.
Hello, I am installing a new meter base and service equipment in a multiple occupancy building. My question is if I need to run my ground all the way to where the grounding electrode of the building is or could I just drive down a ground rod near my new panel. Thanks.
be used.
