Common Neutral from 2 different circuits
Sammy D
New User
Florida
DIY
Installing a new switched light and outlet. The existing circuit for the switched light is different from the circuit for the outlet. However, I only ran one 14/3 wire with ground supplying the fixtures. The hot wires are connected individually in a central electrical box, but I connected the two neutral hot wires and the 14/3 neutral wire together going to the fixture. Both circuits are tripping. When I disconnect the 3 neutral wires and connect them individually, the breakers do not trip. Is the problem my connection of the 3 neutrals?
Thanks for your advice.
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
This NEC® Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
