Re: Common Neutral & Ground
If the breakers are on the same phase, the neutral currents from each appliance will add together. Depending upon the load connected, the neutral current can sum to double the current on the phase legs.
I note:
The 4 wire feeder is connected to dual receptacle box under the kitchen sink.
If, by dual receptacle, you mean two receptacles on one device yoke, then take a read of 210.7(B).
The overcurrent protection must have handle ties, or be a dual trip breaker.
