Re: Communications and Power Cables in Same Raceways ?
the answer is yes and you may not even need a divider in some cases depending on what type of cable you are using and just what you mean by communications circuits. it also depends on what else is actually in the raceway.
BUT, it is probably a good idea to seperate them for noise reduction purposes, and because it is the way things are normally done. less confusion down the road that way.
