I have a request from a customer to investigate possible power quality issues concerning installed communications equipment. The symptoms are as follows: 1) UPS has dropped offline at least once a day for the last 2 weeks. 2) A voltage of 5 volts was measured on the neutral output of the UPS. 3) An individual received a mild shock when he touched the case of the UPS. In my opinion, all evidence points to a faulty or failing UPS. I am not a Power Quality expert by any means and I would like some input as to what specifically I should look for in the system that could be causing this problem to occur other than a faulty UPS. Can anyone help?
