I can't speak for the OP, but to some people the difference between "low voltage" and "high voltage" is whether it is above or below 600V. For others (myself included), the line is at 120V. So when you use either term, it is wise to make sure your listener draws the line at the same point.Fire Alarm said:It's odd that this post was made in the low voltage section.
Fire Alarm said:I've always believed that Medium Voltage was below 600v and High Voltage above. But when you mention "medium voltage" to most people they don't know what you're talking about...
hanh said:What size of the building or size of load should we choose the 480/277V system or 208/120V system?
drbond24 said:Not to resurrect a discussion we've already had in another thread, but I invariably prefer higher voltages where possible. You will have lower currents as a result.
