Michael15956
- NE Ohio
Existing outside fused disconnect with 100amp fuses. The load lugs have #10awg conductors terminated that also run outside underground to a single OCPD rated at 30amps. The OCPD is inside a building nearest the point of entry. Is this a compliant install?
Yes, I know the fuses can be changed, but I'm trying to understand the tap rules better.
