Do the dashed lines indicate the working clearances required by 110.26(A)?
There is no clearance required for the space indicated in red that says "less than 3 ft".
There is a violation of 110.26(A) at the bottom end of SGLN2 and right end of SGLN1.
Are all of the switchgear sections rated 1200 amps or more and 6' or more in length?
Ah yes true bottom end of SGLN2 and right end of SGLN1 is violation. Yes all three are 1200amps or more and 6' more in length. The dotted line is working space as well as the solid line below see. My question is in reference to bolded part:
110.26(C)(2)(b) Extra Working Space: Where the depth of the working space is twice that required by 110.26(A)(1), a single entrance shall be permitted.
It shall be located such that the distance from the equipment to the nearest edge of the entrance is not less than minimum clear distance specified in Table 110.26(A)(1) for equipment operating at that voltage and in that condition.
For GHN what would be the distance from the equipment to the nearest edge of the entrance above code reference bolded part speaking of between GHN and side of stairway labeled in red line " less than 3 feet" or from GHN to the door labeled in red line "5' "?
