compressed airline
I am looking for any information or codes that deals with the correct way a compressed airline should be installed.ie location of shutoff, how much rubber hose can be used, proper piping,support,safetys, etc...
Thanks
hbiss
EC, Westchester, New York NEC: 2014
Hawthorne, New York NEC: 2014
EC
Re: compressed airline
Kind of a strange question for an electrical forum but I was kinda looking for this information a few years ago also.
Short answer is there really isn't anything beyond maybe the local plumbing codes. Some jurisdictions may still require black iron pipe. Most is done with copper and sweat fittings today.
I think OSHA may require "excessive flow cutoff devices" on portable hoses to shut off the air supply if the hose is cut. This is to prevent the hose from whipping around, possibly hurting someone.
There are design practices for compresed air systems, you might go to Ingersol-Rand and see what they have. Take a look also to see if the pipe manufacturer has any recommendations.
-Hal
stars13bars2
Hal is on thr right track as some of the compressor manufacturers have system layouts available. They include things I didn't even think about like running the pipe downhill to water purge valves etc..
steved
Oregon
A lot on industrial plants around my area use a green plastic pipe for air lines. This pipe is specifically approved for compressed air use (ordinary PVC pipe is unsafe for this use and is forbidden by OSHA.) The pipe manufacturer has some information about pipe sizing and support requirements.
