TommyHession
- Needham MA USA
Can compression fittings for rigid conduit be used outdoors none of the manufacturers list their fittings for wet locations
I don't think threaded rigid couplings are listed for that use. Threaded rigid couplings leak a lot more than the old EMT compression couplings that we can no longer use in wet locations. Conduits in wet locations are required to be "arranged to drain". I don't see a real world issue if the couplings leak.If not so listed then no they cannot be used.
Welcome to the Forum.![]()
Why bother with compression when you can go set screw...Can compression fittings for rigid conduit be used outdoors none of the manufacturers list their fittings for wet locations
I don't think there was in the past...it is my understanding that UL changed the listing standard.We use to use standard emt compression couplings outside because we were unaware that there was a product listed as rain-tite.
There are compression fittings listed for wet location but the standard compression fittings cannot be used in wet areas.
The only line of rigid/IMC threadless fittings suitable for raintight applications
The only alternative to field threading in NEC wet locations
I believe RAIN TIGHT is as wet location rated as your going to get with conduit fittings.Would you consider rain tight/concrete tight to be the same as wet location rated? If so American fittings has plenty of options through PLATT https://www.platt.com/platt-electri...Fittings-Corp/NT2761/product.aspx?zpid=823924
See post #9. :blink:Interesting issue - never considered this. I found these: Raintight SSR series by Eaton.
http://www.cooperindustries.com/con...sr_seriessetscrewrigidimcconduitfittings.html
Here are a few selections from the description:
only appear to be made for sizes 1/2 thru 2"![]()
