firstsergeant
New member
Can anyone tell me a different way of tightning large, 2.5"
"-4" compression fittings, besides a very large pipe wrench?
SDS chisel tip in a hammer drill in hammer mode. Big lock nuts - no problem
I picked this up from Electure over on ECN several years ago - I scoffed at the idea until I tried it.I have used my bulldog with just a normal 1/4" bit on hammer mode only to tighten lock nuts. As you said, they will never be tighter, you have to be careful not to cut through the box.
Never tried it on compression fittings, I will keep it in mind.
