S Sadique New User Location Saudi Occupation Quality engineer Feb 17, 2020 #1 needed to understand acceptable length of compression/TERMINAL LUG from bushing towards. Now currently 5 mm seen outward from bus bar. Needed to know is there any standard specific for this. if so please share the number.
petersonra Senior Member Location Northern illinois Occupation Semi-retired engineer Feb 18, 2020 #2 I don't think there is such a thing as long as the flat part of the lug makes good contact with the bus bar.
tom baker First Chief Moderator & NEC Expert Staff member Location Bremerton, Washington Occupation Master Electrician Feb 18, 2020 #3 This is a NEC forum and since you mentioned 5 MM, you may need to look at IEC or orther non NEC information, or in some kind of a mfg spec.
