Re: Computer equipment in Control Cabinets
Jerry, first of all, thank you for the respect.
Now, I don't understand what you mean by "arbitrarily approve something".
As an inspector you would have the substance i.e. training, knowledge, expertise, experience, etc... to remove the word "arbitrarily.
If you "examined" an item and deemed it safe with the above mentioned qualifications under your belt, what else would you need?
Please don't tell me you are misunderstanding 90.7 and 110.3 to mean everything must be third party tested.
Let's look at the issue at hand,a PC being plugged into a receptacle inside a cabinet in an industrial setting. Do you as an inspector look at all cord and plug connected equipment in a facility? This would mean checking radios, clocks, portable lamps, etc...
It seems to me this would truly be an issue under "supervised engineering", and the "supervising engineer" would be the AHJ in this matter.
Roger
