Lamps, drills or tv set plugged into the outlets will work fine fine but if you plug in the computer tower or monitor the ARC breaker will trip after about 10 seconds. Breaker is Sq D QO, any idea what's causing this or how to fix the problem?
Removing the ARC protection is not an option.
thanks
thanks
