Re: computer receptacle
All, there is as much miss-conception about UPS as there is about grounding. UPS systems come in three basic flavors; stand-by, interactive, and dual conversion.
Stand-by UPS that you find used in most homes are the inexpensive types you see in computer and other box stores for the $100-to-$250 price range. These are very simple devices that have a small battery charger, battery, and inverter. In normal operation, the line is connected directly to the load without any form of isolation. If you put garbage in, you will get garbage out. In the event of a power failure, a relay switches the output to the inverter and the battery takes over for a short period of time.
Going up in price is the ?interactive? type UPS which does have some isolation via a static transformer. It still uses a small battery charger and inverter, but the inverter stays active to correct any voltage variations on the output sort of like a buck-n-boost transformer. In the event of a power failure the inverter takes over without any relay control, whereas a stand-by type has to switch which takes time and some occurrence is felt on the output. Prices for interactive type UPS start around $400 and go up with KVA, bells, and whistles.
The third type, ?dual conversion? is the Cadillac and most expensive of the units. These types are what are used in Data centers and can go up to 750 KVA. A dual conversion unit are rectifiers rated for the full output load rating plus enough reserve to charge the batteries in as little as 4-hours, batteries, and inverter. The inverter is on line 100% of the time giving complete isolation from line to load, or input to output. So the process flow in a dual conversion unit is AC-to-DC-to-AC. Units for home use start around $600-$800.
So IMHO advising someone to install a UPS to clean up power is miss-leading if a stand-by type is used.
