Computer workstations
charlie b
Lockport, IL
Semi-Retired Electrical Engineer
How much power does a typical desktop computer with two monitors draw? If I serve such a workstation with a double duplex, should I count it as 360VA, or something higher, or can I justify something lower?
rp9ball
WI
workstations
workstations
The tag on my power supply input is 120V and 7 amps : 2 Monitors 120V and 1.2 amps each.
Basic system low end system: no upgraded graphics card. Amp clamp reads 3.7 amps.
Hope that helps
charlie b
Lockport, IL
It does, thanks. The problem went away on its own (i.e., someone else performed the calculation, and I am off the hook). So I will close this thread.
