Flyfishman
New member
We are doing a major 12.46kV distribution project where we proposed a single conductors with a shield tape cable (to be used to protect the actual cable)and separated ground conductor installed in PVC Conduit. The plant staff says that want concerntic neutral cable which they plan on using as a ground and delete the separated ground conductor. We have always been under the impression that you can't use the concentric neutral as a ground conductor.....Please give opinion
