Someone asked me if I could wire a concession trailer. The electric requires a 240 volt, 30 amp circuit. The trailer has a 75' cord and I plan on running an outlet that far away. The length of the cord will be on the ground. I have two questions. Would you recommend a GFCI breaker? Would you run a ground rod to the trailer? Normally I would, but the trailer would only be used for one day. Would the EGC suffice in lieu of a ground rod? Thank you!
