Tapcons for most items here.
One key is to use a slightly different size bit depending on material.
Soft old brick needs a smaller bit while hard cement needs to be a bit bigger.
I use a inpact tool for driving. Make sure the drive bit is not worn out.
Allways use the larger size, 1/4 with the hex head.
Also a cordless drill set on low hammer mode works good for driving.
Corded drills never worked well for me.
Many times they can be tightened or loosend with a screw driver such as to amake an adjustment.
Also keep in mind hollow spots and where the bulk of the thread is at on the tapcon.
They have stainless tapcons listed if you want the look but have never seen them.
http://www.itwbuildex.com/catpdf1/tapcon.pdf
1/4x1" Tapcons in 2000 PSI concrete can hold 750 lbs tension and 900 shear.
