Alwayslearningelec
- NJ
- Estimator
Are the concrete bases for pole lighting usually the electricians responsibility? If so, an someone give a brief overview of what's involved from your experience.
I would have to tell them that if the conduits and bolts are not where they are not supose to be than you don't get paid.SEO said:We get involved for the simple reason that I want the anchor bolts and template in the correct location and conduit in the middle of the tube.
We plant precast bases that we make ourselves
Unless the last person that did those bases does them like me. Mine are more like upside-down mushrooms. 24" sonotube above ground, and about a 5' around concrete footer underground. Keeps the poles from getting out of whack over the years from snowplowing.220/221 said:In a couple weeks I am going to attempt to relocate 5 poles and bases.
220/221 said:I'm liking that idea.
In a couple weeks I am going to attempt to relocate 5 poles and bases. I have to pull the bases out to make room for a parking structure so I was thinking I could pluck them out, drop them in another hole and fill with slurry.
In the past I have jack hammered bases below grade and they paved over them. This time I want to try something new. It will be labor intensive but will save a couple thousand dollars in concrete, rebar and dump fees.
horsegoer said:Are the concrete bases for pole lighting usually the electricians responsibility? If so, an someone give a brief overview of what's involved from your experience.
220/221 said:I usually have to do them for logistical reasons.
Use a palm sander, a sawzall with no blade or a baseball bat repeatedly on the exterior of the tube to fill the voids.
220/221 said:7. 4" putty knife will finish the tops in an acceptable manner but not until it's ready to be finished. Too wet and you will just chase the lines around. I'm not sure how they get that nice rounded outside edge unless the strip the form while its still managable. Maybe some special tool. A hand edger doesn't works because it's square.
