Concrete-Encased Electrode Size
Desert Sparky
Desert
Electrical Engineer
I've read dozens of threads on the forum regarding this topic, but I've not seen an answer to the following specific question:
Assume I'm bonding all grounding electrodes together present at my building, to include building structural steel, cold water piping, concrete-encased electrode, and (2) ground rods per NEC 250.50. Per Table 250.66, my GEC should be #1/0 based on service entrance conductor size.
Does my concrete-encased electrode also need to be #1/0, or can it be #4 AWG as described in 250.52(A)(3) and just be bonded to the rest of the grounding electrode system with a #1/0?
250.66(B) #4 is fine
My understanding is that 250.66(B) describes the size of grounding electrode if that grounding electrode is only connected to a concrete-encased electrode (and nothing else). My question is about the size requirements of the concrete-encased electrode itself when there are multiple grounding electrodes present and bonded together (and our grounding electrode is larger than #4).
Regardless of what size the GEC must be the jumper (connection) to the CEE never has to be larger than #4 and the jumper (connection) to any rods never has to be larger than #6
To have a CCE you need 20' of rebar or 20' of #4 copper.
I'm not sure I understand your question. As Dave stated there are two ways to have a CEE, either the rebar or a bare copper conductor.
The CEE in this scenario is bare copper conductor; as such, does the size of this CEE have to match the size of the GEC? Or is it acceptable to bond a #4 CEE to a grounding electrode system installed with a larger GEC (in my case, a #1/0)?
No the connection to the #4 CEE can be larger than #4. It can also be smaller than the #4 CEE when the service conductors are very small.
We're trying to explain that the GEC to the #4 cu CEE need not be larger than the same #4 cu.
No. A CCE is either 20' of rebar or 20' of 4AWG in the footer of the building. The conductor connecting to the CCE never needs to be larger than 4AWG
Sure.
