jmsbrush
- Central Florida
What is the average cost of a concrete slab to set a 25K liquid cooled generator for a residential application?
What is the average cost of a concrete slab to set a 25K liquid cooled generator for a residential application?[/
what are the dimensions of the slab?
About equal to a couple of 2x6's and a few of bags of Quikcrete.What is the average cost of a concrete slab to set a 25K liquid cooled generator for a residential application?
Quite a few bags of Quickcrete, you will quickly learn to make it 2x4's instead of 2x6's:grin:
Okay, how about a dozen or so pavers?Quite a few bags of Quickcrete, you will quickly learn to make it 2x4's instead of 2x6's:grin:
The slab will probably be around 4.5x 8.
At 4" thick, about 18 80# bags of sacrete.
At 6" thick, about 27 80# bags of sacrete.
I'd make sure I had a couple of extra bags.
A mixer would be in order too.
does anyone use rebar in the slabs? we usually put a few sticks inside to make it a little stronger
Never did a generator pad, I have made a few housekeeping pads. I just rent a small mixer from HD when I get the bags of redi-mix.
I do include wire mesh and rebar pin them to the existing slab, I round over the edges and provide a broom finish.
The last one I did stated with 2 x 8 s just so the thinest area was 4", the floor had a heck of a pitch.
nice work :smile:
If you do it your self don't forget a wheel barlel to go from the mixer to the pad.
