Hi, everyone,
Please forgive the newbie question, but, this one really has my dad and I stumped. He is an electrical contractor with 42 years of experience, so, he is the one who will be performing any tasks. Thanks for your understanding.
Here's my question:
I live in a relatively new home (about 4 years old). My panel and meter are located on the south side exterior of the house. Whenever there is a sharp increase in humidity coupled with a decrease in temperature, a huge amount of condensation develops in the panel. The panel is made by Siemens and appears to be an outdoor-rated panel. I discovered the condensation problem when the AFCIs on the bedroom circuits were tripping. I'd go to reset the breakers and they'd continue to trip. I then discovered that the inside of the door and the bottom of the panel itself was covered with water. I went ahead and pulled the inner cover off to see where the condensation was coming from. I couldn't find any obvious sources. I did, however, pull out one of the AFCIs. About a quarter teaspoon of water poured out if it. My father came by and replaced it, however, he couldn't find the source of the condensation either.
The house is on very sandy soils, so, we thought that moisture might have been coming up through the conduit for the service (service is buried). So, I injected the conduit between the meter base and the panel with expanding foam insulation and added thick, foam tape-type weather stripping to the door of the panel to try to keep it dry inside. Neither of these solutions have worked.
Other than the obvious safety issue that this creates, I'm getting pretty tired of having to wait for the AFCIs to dry out before I can reset the breakers.
Have any of you heard of this and is there a real solution??
Thanks so much for your help.
Here's my question:
