Re: condensers
Are you perhaps talking about a capacitor? "Condenser" is the outdated name for capacitor. If so, capacitors are used in starting and running the compressor and fan motors.
In the cooling cycle however, a condenser does literally that; it condenses the hot, high pressure, gaseous Freon (from the evaporator) into a liquid. This process removes heat from the Freon. This liquid is then pumped back to the evaporator where it is vaporized by the room heat and low pressure from the suction side of the compressor. The compressor compresses this cool gas which raises its temperature and pumps it into the condenser again to complete the cycle.
The condenser and evaporator coils are similar to an automobile radiator. Both are heat exchangers. The evaporator absorbs heat, and the condenser dissipates heat. The compressor changes the pressures and keeps the refrigerant (Freon) moving. Fans or blowers are required to force the air over these coils.
[ September 21, 2005, 12:09 AM: Message edited by: rattus ]
