I need help sizing a disconnect for a condensing unit. The nameplate rating for the unit is as follows: MOCP = 40A, MCA = 23.5A, 208V 3phase. Based on this information I will have 40A circuit breaker in the panel using #10AWG wire (could have used #12) and a 3pole non-fused disconnect at the unit. In this case do I use a 30A disconnect based on a MCA = 23.5A or do I use a 60A disconnect base on a MOCP = 40A?
Thanks
Thanks
