I have a condo project that has a building divided into 10 "modules" comprised of 3 units each. The modules are separated by block walls, and each module will have a meter pack serving its three units. So each module is a "building" served by one service entrance. My problem is that I'd like to have only one house panel for common lighting, etc. This lighting consists of lights for the common garages (each built under two units), a hallway between each garage and a unit, and three exterior wall-mounted lights. The exterior walls are framed - not block - and some of these lights are on them. Do I have to have ten house panels to satisfy the "building served by one service" rule? Should I go to a single main breaker SES with meter packs fed by it? How do you do that? I am used to doing commercial jobs and haven't worked much with residential modular metering much.
Thanks.
Thanks.
