Re: Condo Metering
Generally, a service may only have 1 service. Unless there is a fire wall (not fire partition) separating them, the condo's comprise 1 building and should only have 1 service. Not a separate service on each unit. Fire wall is defined as "a fireresistance rated wall having protected openings, which restricts the spread of fire and extends continuously from foundation to or through the roof." It's further stated that "Walls should have sufficient structural stability under fire conditions to allow collapse of construction on either side without collapse of the wall, and should be constructed of any noncombustible materials that provide required strength and fireresistance rating specified in table....." This is from the Massachusetts State Building Code. I would imagine that the IBC has similar wording.
So typically you would need a condo metering bank, and as stated previously, probably a "house" meter.
