A single structure consists of 6 condos. Service equipment will consist of a meter pack with 6 utility meters with 6 main cb's (Square D Meter-Pak or some such) and is mounted on exterior wall of building. Each meter feeds a load center in each unit. Next to the building are detached garages, three separate buildings with two garages each. (I am borrowing this idea from someone else in the forum).
111222333444555666 main bldg
111222333444555666SE service equip on this side
111222333444555666
111222 333444 555666 detached garages
225.30 says separate buildings "under single management" shall be supplied by one feeder or branch circuit. In our case, the garages need to come off the associated tenant's meter because there is no "house" or "common" meter, so there would be at least one branch circuit from each tenant's panel to their garage, two circuits total to each garage building. Does 225.30 not apply because the buildings are not "under single management" since each condo is individually owned? Where apartments have detached garages, are they usually on a house meter? Our local plan reviews and inspectors are of the variety where if it's never been seen before it must be wrong. Any thoughts, experiences, ideas would be appreciated.
111222333444555666
