what water pipe are you asking about?Hi, kinda dumb question but, if you're doing a sub panel swap on a condominium unit, does the water pipe need to be bonded to the sub panel?
I don't see a need. Presumably it is already bonded at the N-G bonding point upstream somewhere.No, I meant the bond to the copper water pipe. The water heater is electric and is grounded.
Are you asking about a Grounding Electrode or simply bonding the water piping per 250.104?No, I meant the bond to the copper water pipe. The water heater is electric and is grounded.
No just the water bond.Are you asking about a Grounding Electrode or simply bonding the water piping per 250.104?
Then post #2 is goodNo just the water bond.
