Conductor and ocpd sizing for a/c heat unit
Necnerd
colorado
ME
I’m sure I’m overthinking this but wanted to make sure I didn’t miss anything nec wise. The unit shows 4800watts/240v=20amps on the plug. The books says nema 620-r receptacle. I planned on running a 240v circuit using 12-2nm and installing the 6-20receptacle
Can’t go wrong with the nameplate data.
That plug will only fit in a 240 volt, 20 amp receptacle so that is the configuration of the branch circuit that's required.
