CM Phillips
A code official has rejected an installation citing 300.34. The inspector is indicating the panel feeder (in this case a 250 kcmil neutral) cannot exceed 175 degrees in one bend. First of all 300.34 applies to conductors over 600V, which this is not. Secondly 300.34 applies to bending radius being equal to or greater than 8 times the overall diameter of the conductor. Is there any other reference or requirements listed in the code that would prohibit a single conductor bend exceeding 175 degrees? I have not heard of any restriction, and can think of multiple "standard" practice installations where this would be violated if it were true. This installation is for a standard branch panelboard where harmonics, and similar concerns are not applicable.
