Rodie Radermacher
New member
Table B.310.11 and the following FPN show how to calculate conductor ampacity for up to 85 conductors in Raceway with Load Diversity. How is ampacity calculated with more than 85 (actually 120) conductors??
By hiring a licensed PE to run a software package that uses the Neher-McGrath process. Sorry that I can't give a better answer, but I think that this is the only answer.Originally posted by Rodie Radermacher:
Oops, I think you already knew this. Just call me redundant.
Originally posted by flip: I believe the appendix in the back of the code book tells you how to do it.
I think the point of the question comes from the FPN located just under that table. It specifically states that the table does not apply, if there are more than 85 conductors. What you need is a calculation that is performed "under engineering supervision." I wasn't kidding with my previous response.Originally posted by redfish: Annex B, Table B.310.11
