mark32
- Currently in NJ
I was asked to troubleshoot a dead receptacle circuit at a daycare. No voltage present at first rec in the circuit and no continuity from the grounded conductor to ground, but had voltage present at the breaker terminals. Tried pulling on the conductors, 12 solid in emt (Embedded in concrete) with old brittle insulation, but they wouldn't budge, hooked up the tracer but the signal dropped off within a few feet of the receptacle in question, nor sure if that was accurate or not. Owner says no breakers have tripped in some time. I finally decided not to waste anymore time on the existing issue and told the owner I could refeed the circuit with ac or mc. Two questions, how could both conductors fail like this and do you typically charge for troubleshooting when the troubleshooting leads to installing a new circuit, etc. For example, if the owner has me to fix this with my solution then I should eat the troubleshooting charge or add that into the cost to repair this circuit? In reference to the troubleshooting itself, no one but a plumber had been doing any work in the school since this circuit failed.
