NEC 300.3 Conductors
(B) Conductors of the Same Circuit. All conductors of the same circuit and, where used, the grounded conductor and all equipment grounding conductors and bonding conductors shall be contained within the same raceway, auxiliary gutter, cable tray, cablebus assembly, trench, cable, or cord, unless otherwise permitted in accordance with 300.3(B)(1) through (4).
Isn't the fundamental requirement of this section that single conductors shall be grouped together to mitigate the parasitic effects of magnetic and electric fields. One of the ways to achieve grouping is by using conduit/raceways etc. If a raceway etc is used, all conductors of the circuit must be contained therein.
There are other ways to achieve grouping of conductors to keep them in close proximity such as staples, straps or other acceptable wiring procedures. Wouldn't interlacing or weaving them together as in CAT V UTP cable assemble, achieve the same mitigation requirements?
From an installation concept, placing conductors into a conduit may be the defacto standard, but is it the only way?
Ian
Ian
