The conductor impedance comprises two parts, R and Z.Why would (2) sets of 500 kcmil have a lower impedance than (1) set of 1000 kcmil according to Table 9
Some, but not a lot.Skin effect at 60Hz.
It goes from about 1.10 to 1.03 as a ratio of Ra/Rc (alternating to DC).
Source is Emmett (Alternating Current Wiring and Distribution).
Is that resistance or impedance?Looking at table 9, for PVC so that magnetic induction effects of the conduit are not important, 500kcmil = .027 ohm/1000ft. 1000kcmil - .015 ohm/1000ft.
That is just resistance, and in a non-magnetic conduit. The OP asked about resistance, and so that was what I concentrated on.Is that resistance or impedance?
My figures for the paralled conductors make their impedance about 0.75 of the single conductor.
The ratio of their resistances is 0.95.
... this is usually not as important as the skin effect.
There is another thread ongoing about 400Hz power wiring..But, for higher frequencies it can have a profound effect.
Jim,Which is all but negligible at 60Hz and below 250kcmil. Even at 500kcmil it is rarely as high as a 1.1X correction ratio.But, for higher frequencies it can have a profound effect.
Bingo!Jim,
That said, why is there so much more ampacity (per the NEC Tables) per circular mil when using most parallel combinations vs 1conductor (at 60 Hz)? Is it due to more surface area for cooling? I always assumed it was due to skin effect. I may be getting an education here.
But from the OP, post #1:That is just resistance, and in a non-magnetic conduit. The OP asked about resistance, and so that was what I concentrated on.
We don't use conduit. I did figures for non-armoured and armoured (steel wire armoured. The figures were the same. You might expect since the magnetic fields from the conductors ought to balance.However, the resistance and the reactive components when in conduit have a greater percent difference.
Yes, surface area for the most part.Jim,
