Jack Winburn
Hello all:
Could you tell me the difference between MCM cable and KCMILL?
thanks
thanks
Hello all:
thanks
The term MCM was defined as 1000 circular mils (the first M being the Roman numeral designation for 1000). Beginning in the 1990 edition, the notation was changed to 250 kcmil to recognize the accepted convention that k indicates 1000. UL standards and IEEE standards also use the notation kcmil rather than MCM.
Why would that be? :-? The "K" means 1000, the "C" means "circular," and the M" means "mils." So where would 100,000 come into the picture?A few years back someone noticed the KCM means 1000 circular mils, when it should have been 100,000 circular mils. . . .
why would that be? :-? The "k" means 1000, the "c" means "circular," and the m" means "mils." so where would 100,000 come into the picture?
now my knowledge of roman numerals may be off, but that is the jist of it.
In 1990 the NEC decided to start using SI (international scientific notation), for all of its dimensional measurements. In effect this put the NEC on the Metric system, which uses Greek numerals for its prefixes, such as K (or sometimes k) meaning 1000 times.A few years back someone noticed the KCM means 1000 circular mils, when it should have been 100,000 circular mils ...and so MCM came to be.
I'da thunk from Roman numerals.I suspect that the "M" in "MCM" comes from the French word for one thousand.
Thanks for the insight. We are running some 350 as a main feeder and we have left-over spools of both MCM and Kcmil. I guess I am safe using both.....
Hello all:
thanks
Tourist: "Is this state's name pronounced 'Hawaii' or 'Havaii'?"One is a po-tay-toe, the other is a pu-tah-toe.![]()
I don't understand,Actually, it should be square mils instead of circular mils. . .
From the handbook:
"The circular mil area of a conductor is equal to its diameter in mils squared (1 in. = 1000 mils)."
Taint so! Pie are not square, pie are round. Cornbread are square!The formula is area = pi()*R^2.
