Conductor min. voltage rating in starters
gsc
New member
Is there a article in the NEC that would require all wiring in a 480VAC motor starter to be 600VAC rated, including the wiring to a 24VDC coil or contact circuit as part of a motor control circuit?
iwire
Massachusetts
Re: Conductor min. voltage rating in starters
Yes, 2002 NEC 300.3(C)(1)
Here is part of it
All conductors shall have an insulation rating equal to at least the maximum circuit voltage applied to any conductor within the enclosure
