Re: conductor sizeing
Roger is correct you must use the 75 or 60 degree rating depending on the rating of the lugs that the feeder is connected to. The 90 degree rating can be used for derating purposes. I would also add that the feeder ampacity to the VFD must be sized for the VFD and not the motor.
