scottbrown
A question that I thought would be easy to answer. I have an application where conductors providing power to pole lights are spliced inside of the poles. There is a hand hole at the base of the pole but the splice is above to hand hole far enough that you can't reach it. The question that I have is if this is a violation of the NEC. Also, when conductors are spliced, can the splice be inside a piece of conduit (as opposed to in a junction or pull box). I would appreciate chapter and verse of applicable code references.
Thanks in advance,
Thanks in advance,
