Butler said:When installing a 100 amp breaker with 2AWG SE cable feeding a 100 amp sub-panel the neutral bar terminals in the dwelling unit 200 amp panel are not large enough for the 2 AWG aluminum SE cable conductor. What is the proper wiring method?
Unless it is for 240 Volt loads only, where no neutral condcutor is needed, such as a large heat pump scenerio.benaround said:Butler,
A 'sub panel' needs 4 conductors, Type SE cable has 3, unless it is SER
type cable your installation is NOT code compliant.
