knight1fox3
Hello,
In doing voltage drop calculations with the use of Table 9 in NEC 2008 (effective Z at 0.85 PF for copper wire), I've encountered a question asking if this calculation can be done for 90 deg. C as opposed to 75 deg. C which NEC Table 9 specifies. It is evident that NEC 2008 does not publish a table with resistance/reactance values for 90 deg. C. Could the effective Z listed in the table be adjusted using the appropriate temperature coefficient of copper? Any feedback or past experience with this issue would be greatly appreciated. Thanks in advance.
