If you are installing conductors in free air in an electrical vault, feeding more than one service from seperate transformers, and you have your service feeders coming into bottom of switch gear, voltage is under 600 volts, can your service feeders cross over or under from one service to another. Also can your load side out from gear cross over or under your service conductors coming from transformers without dividers or barriers. What would the code article be for above.
