I am trying to install the below RH sensor. I would like to find some conduit for the wires and some strain relief for the wires coming out of the actual sensor. The transmitter will be installed inside of a junction box, with strain relief coming out of the junction box.
The sensor is removable from the sensing environment, so I would like to have strain relief for the wires coming out of the sensor. I would also like to find some flexible conduit that would allow me to coil the wire. I have some ex-flex sleeving that would work, but if I can get any suggestions on anything better I would appreciate it.
Also, the board is 24VDC class II supply. Would you recommend a metal or plastic junction box?
