I Was Asked The Question If Conduit Could Be Used As The Equipment Ground. We Ran Into A Situation Where A Control Panel Required 3 Phase, Plus A Neutral And A Ground. However, The Neutral Was Not Pulled And The Contractor Is Saying Thay Would Have To Pull All The Cables Out To Add The Neutral. What Was Pulled, Was 3-1/0 And A #6 Ground. So We Thought We Could Use The #6 As The Neutral For Some Lighting And Then Bond The Conduit On Either End. Any Suggestions? I Was Told The Code No Longer Allowed This Practice.
