Maybe a ruler/tape measure that doesn't have the numbers worn offOriginally posted by lew3611:
....my biggest problem is getting my measurements right. Does anyone have any suggestions?
I had to think about this one for a while and I think I got it.Originally posted by wannabe:
I would take a"terminator" over a bender any day.!
You are putting the 80" length out the back and not the front of the bender.What am I doing wrong here? using a chicago bender
If you bend a back to back, then the 80" will be parallel to the floor. If you stick the 80"-12 3/8" in front of the bender the 80" will be up in the air. As a general rule once the required length of the 90 is over 60" I would be bending using the back to back method.either way once done bending I should 80" in the air instead of 71" parallel to the floor, right?
