sparkmantoo
- Virginia
we were discussing the bends that can be made in a conduit run between junction boxes or whatever. we were discussing the maximum degree you can make in a SINGLE bend. someone mentioned a "shepards hook" bend. it looks kind of like a question mark, and it application is used for a run say up the wall and then have to ninety through it. in order to do this you must overbend the ninety and then flip the pipe around and pull the back side up until it come out ninety degrees.
i seem to recall that the code says no more than 4 quarter bends in any run between j-boxs, conduit bodies, and also shall not be less than the inside radius designated by table 344.26 i think. i don't have the book here. my interpritation is the quarter bends are just that quarter bends (4x90=360) and to make more than a 90 degree bend (single bend remember) is exceedind that rule and also the inside radius is smaller because you have a tighter ninety. any thoughts on this people i would greatly appreciate some feedback.
