In regards to 314.23 (E) Ex, it states that IF your conduit body is larger than the raceway trade size, then it needs to be supported. To say it in Mike Holts words via his book, “IMC, RMC, PVC, RTRC, and EMT can support a conduit body if the trade size of the conduit body isn’t larger than the raceway.” Therefore, with that objective fact being stated, my question is if a larger conduit body such as an LB (2 1/2”) were used with a 2” RMC raceway, then how do you practically and mechanically support an LB? Upsizing large LB’s is fairly common to make wire pulling easier, however, I’ve never seen an LB itself be supported.
