ryan_618
- Salt Lake City, Utah
314.17 tells me that
300.4 says:314.17 Conductors Entering Boxes, Conduit Bodies, or Fittings.
Conductors entering boxes, conduit bodies, or fittings shall be protected from abrasion and shall comply with 314.17(A) through (D).
(D) Conductors 4 AWG or Larger. Installation shall comply with 300.4(F).
Notice that the exception does not include conduit bodies...but then again, neither does the charging language of the code section. I can't think that a conduit body would require a plastic bushing (in fact, I'm not sure that it is even possible), but the code sure seems to require it!(F) Insulated Fittings. Where raceways containing ungrounded conductors 4 AWG or larger enter a cabinet, box enclosure, or raceway, the conductors shall be protected by a substantial fitting providing a smoothly rounded insulating surface, unless the conductors are separated from the fitting or raceway by substantial insulating material that is securely fastened in place.
Exception: Where threaded hubs or bosses that are an integral part of a cabinet, box enclosure, or raceway provide a smoothly rounded or flared entry for conductors.
Conduit bushings constructed wholly of insulating material shall not be used to secure a fitting or raceway. The insulating fitting or insulating material shall have a temperature rating not less than the insulation temperature rating of the installed conductors.
