I would imagine in doing so you have voided the UL rating and intended use.
which is pretty strange to me. What is an LB but a type of J-box? Has a lid, accessible sides, splices are permitted in them.
I can take a regular PVC J-box with a lid and pre-formed conduit connections like an LB, and add openings with a hole saw all day long.
Threaded raceways are permitted to support boxes under certain circumstances.Well, for one thing, a junction box cannot use the conduit as support. An LB is not a type of J-box, anyway. It is a fitting.
Is it a violation to hole saw and connect an additional conduit into the side of a PVC LB? What if a gasketed hub were used?
Does the NEC call an LB a "conduit body"?
That's what we call them in manufacturing.
What do you think a box is? Lol.Breezing through Art. 314, I see where an enclosure is permitted to be supported by the raceway if the enclosure is threaded, or threaded hubs identified for the purpose are used.
In order for a box to be support by the raceway alone, said raceway needs to be threaded (imc or rmc) and installed/ supported a certain way.That's all I was saying.I was responding to your post that said 'threaded raceways'. It doesn't matter if the raceway is threaded or not. The article addresses the enclosure's method of connection, not the raceway's.
A box is not a conduit body which is defined as part of the raceway and excludes boxes. This thread is about a modification of a conduit body. Conduit bodies have different rules than other types of enclosures.
Conduit bodies are allowed to use conduit as support by exception. Other enclosures either have to be threaded or use a hub identified for that purpose. The idea is that a connector does not need to be used on a conduit body. It is 'part of the raceway'. Drilling a hole for raceway connection requires a connector and thus is not part of the raceway.
One question, does the modification of the conduit body relinquish it from the exception?
Another issue. Would the connectors be listed for use to connect a conduit to a conduit body?
