conduit depth
dhsvcs
miami
electrician
I did a search and found this...
AI Overview
Learn more…
The National Electrical Code (NEC) requires that PVC conduit be buried at least 18 inches deep for residential installations and 24 inches deep for non-residential installations. However, local electrical codes may require depths up to 30 inches depending on the application and exposure.
In a common area in a condominium complex ( NOT parking or roadway ) I encountered many pvc conduits with less than 12" of cover.
The compex is old ( built in 1970 ) but I would think that 120/240 volt conduit would need 18" of cover.....
Am I correct ??
1970 was a long time ago. Have the minimum depth requirements in Article 300 changed since then?
